Theme problem when I open it on my phone
Salut,
I have a problem with the theme when I open it on mobile devices.
The problem is that the theme shows the code not the image.
You can check this at mobile friendly test
https://www.google.com/webmasters/tools/mobile-friendly/?hl=ro&url=http%3A%2F%2Fwww.travelguideromania.com%2Fro%2F
I wait for your advice,
Thanks,
Bogdan
Salutare Bogdan,
This issue is a well known one to us. It is caused by the jetpack mobile theme. Please deactivate this option and your website should return to normal.
Thank you bogdan for your support.
All the best,
Bogdan
