Theme translation does not work
I have a problem with the translation of the theme (english > french).
I followed this tutorial : https://forum.tagdiv.com/loading-translations/
But it doesn’t work (cache cleared), the site is still in English (“by”, “updated”, “share”…) and not in French.
Thanks,
  • This topic was modified 6 years by LPresse.
Hello !
Those you can find and translate manually here: https://www.screencast.com/t/Pmr2qxvQfUh
Thanks for your reply.
I did it.
Everything is translated into French in Theme Panel, but it doesn’t show up on the site.
Site remains in English…
  • This reply was modified 6 years by LPresse.
[Update] It works with the “Share” button, but it doesn’t work with “by” and “updated” in an article.
Please provide me a link where I can check this, is possible to be some elements that can be edited using tagDiv Composer https://i.imgur.com/dd2dOzc.png -> https://i.imgur.com/Ht8j0Yf.jpg
I cannot provide you with a link because the site is offline, it’s under construction.
We use Newspaper — Romania News.
We can edit some elements with tagDiv Composer, but this only modifies one article and not all the articles of the site.
We want these changes to spread throughout the site.
Thanks,
If you are using the Romania News Pro then you are using a pro demo, this is using cloud template from tagDiv Cloud Library, therefore you can use tagDiv Composer to edit a template and this will be the same on all elements that has assigned that cloud template.
For example if you want to translate the word “By” then -> https://i.imgur.com/g9PahXN.png -> https://i.imgur.com/nMBM6Oh.png this will apply on all posts is the same fore updated text -> https://i.imgur.com/69W81Ql.jpg
It’s works fine !
Thanks !
