Long story short. Something must have been corrupted in a Newspaper theme file. Hosting helped, had to do a theme restore, then a full site restore.
Hoping to be at the last mile of the fix… I cannot edit ANY templates. Gives me an error. Which I am hoping is related to another issue. It tells me I need to update from 12.6.9 –> 12.73. I click to update, take me to a screen that says everything is up to date. Which it isn’t, because it still says Im on 12.6.9.
TLDR. Restored, assume I was on 12.7.3 Now stuck on 12.6.9. And wont let me edit templates, Im assuming because it partially thinks Im on 12.7.3/12.6.9? Child theme too FYI. Screenshots included.
HELPPPPPPPPPPPPPPPPPP
michaelryanmoney.com
Screenshots
UPDATE: Sorta…
unable to edit any templates (e.g., post or category templates). When I attempt to open a template for editing, the Composer editor either fails to load, displays a blank screen, or encounters an error, preventing any modifications.
Crucially, the TagDiv Composer seems to work for editing regular pages and posts. I’m guessing the problem is specifically localized to the template editing functionality?
I’ve already done many troubleshooting steps, including:
WordPress & Theme/Composer Versions:
– My WordPress core is up-to-date. 6.8.3
– Dashboard says WP, Themes and Plugins are all up to date. but on the Newspaper updates page it shows I need to update to 12.7.3
– Newspaper theme currently updated to 12.6.9, can’t upto to 12.7.3
Theme Reinstallation Attempts:
– I’ve tried a significant process to ensure theme integrity: I manually downloadeed 12.7.3 from ThemeForest and then performed a fresh, clean update to the current latest version of the Newspaper theme and its associated plugins. This was done to rule out any corrupted files. It wont et me update though, it doesnt complete it.
Site Restore:
– I performed a full site restore from a recent working backup, but the template editing issue persists.
Caching Management:
– I have thoroughly cleared all levels of caching: my WordPress caching plugins (e.g., [mention specific plugin if you use one]), server-side cache via my hosting provider, CDN cache (Cloudflare, etc.), and my browser cache (including incognito mode).
PHP Environment Configuration:
– I have verified my server’s PHP version (currently running 8.3.22)
– I have also manually increased critical PHP limits in my php.ini and wp-config.php, including:
– memory_limit 1024M
– post_max_size 1024M
– upload_max_filesize 1024M
– max_execution_time 600
– max_input_vars 5000
WordPress Core Diagnostics:
– I’ve checked the WordPress Site Health tool, and it reports no issues
– I’ve re-saved permalinks from the WordPress settings.
– I’ve tested editing in different browsers, ccomputers and incognito/private windows.
Plugin Conflicts:
– While pages/posts edit fine, I have also systematically deactivated non-TagDiv plugins that might interact with editors or custom content types to check for conflicts, but the template editing issue remained.
My leading hypothesis is that the problem may be tied to a version mismatch or conflict? My current system is detecting Newspaper Theme 12.6.9, while it seems certain theme components or template assets might have been created or are expecting an environment compatible with Newspaper Theme 12.7.3? This discrepancy appears to specifically affect the way TagDiv Library interacts with or loads template files, as all other Composer functionalities for pages and posts appear to be working correctly.
Could you please provide guidance on this specific issue? I can provide screenshots, access to the browser console, or temporary admin access if needed.
Thank you for your urgent attention to this matter.
This reply was modified 1 year by
mikeshecky.
Thanks for that tip. It DID work. Got me to 12.7.3
Half the problem was solved. Other half, no such luck.
But. Posting an update below for anyone in the future if they have a similar problem
So, long story short. And when I say long…
Anyway, turns out. Host was able to fix the problem. Although everything pointed to it being Newspaper issue. An amazing support rep at Rocket figured it out.
Posting here in case anyone ever has a similar issue, so a potential solution may be documented
They I added this on htaccess
Header always set Content-Security-Policy “frame-ancestors ‘self’;”
And that seemed to fix it
The CSP rule was just too strict after the restore. It blocked the page from loading inside the TagDiv Composer’s iframe.
Once the rule was adjusted to allow framing from your own domain, everything clicked back into place.
The server itself was working fine; it was just the browser being told “don’t show this page inside another page.”
