There is a problem with td-composer plugin
We are facing many issues with this plugin td-composer. please check and fix the problem with it as soon as possible.
Waiting for your quick reply
What issues do you have? Please provide more details.
Yes sure,
1st problem is the featured images are not showing on the homepage and articles on everywhere.
2nd Hostinger shows that this plugin td-composer has malware.
Please check the screenshot below
Feature images Or Thumb problems also have malware this plugin
I can’t see you screenshot
Check this screenshot also here https://app.screencast.com/LAvIrM0gzBfwp
Hostinger Security option saying that, this plugin td-composer has malware
For malware, please check this topic https://forum.tagdiv.com/topic/security-vulnerability-reported-in-composer-again/
For thumbs please go to the theme panel -> block settings -> inline css and disable the option to minify the css and clear the cache.
I have checked this also https://forum.tagdiv.com/topic/security-vulnerability-reported-in-composer-again/
But, there is no helpful solution there
Disabled also MINIFY INLINE CSS
Check the screenshot also here https://app.screencast.com/oQMJBOEkYXLvu
Feature images/thumbs still not showing
The problem is fixed. You need to follow the steps to check all files, of the wordpress and plugins.
Also, I checked the website and the image are displayed https://i.imgur.com/JURJR9I.jpg
I have done the issues about the feature images/thumbs by myself.
You need to fix the malware from plugin td-composer
I have done it by myself.
You need to fix the malware in the plugin, which appears on the all websites td composer
The is not on only the website, the malware is on my 10+ websites. all websites have paid theme and still registered
You need to do all the steps for all websites.
