These problems show in all posts.
In view mode (as visitor) the row is separated 50% width for each column, when I edit it it shows ok. (I have tried to edit global layout and one single page layout)
Live Version: https://prnt.sc/uFwt10eaT0yw
Edit Version: https://prnt.sc/ULKZ0JYWBDS0
Footer problem (shows in every page/post except home page).
It’s the same error/problem as post in categories. In editor view (I have tried to edit global layout and one single page layout)
When I edit the footer everything it shows as I design it, but when I open any other page, post or anything except home page it shows problems.
Live version: https://prnt.sc/0_fVt0E70w0b
Edit Version: https://prnt.sc/WLjU0Oc0_s8O
Homepage Version: https://prnt.sc/JFzIfRLxd_gI
In pages or post (except home page) it have padding right and padding left both 24px for entire container. If I make it 0px (with additional CSS) it will break entire page. I have trying it with other pages, categories or posts.
Problem: https://prnt.sc/2ePOzcK-TqAK https://prnt.sc/dMZ_QMGKKcfi
Home: https://prnt.sc/AKnnVi-6xhZL
LightshotLightshot
Usually, this problem can appear when you are using the WPBakery if you have this plugin enables then please disable it and try again. There may be a conflict between WPBakery and the tagDiv cloud library.
Make sure there is not a plugin conflict or a cache issue. Please make a test, deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
