Third party SEO on review posts
Hi folks
We’ve noticed that on Review posts third party SEO (Yoast) plugins are blocked from adding metadata. Even with the Schema button switched off in the dash and reviews on blocks disabled.
It’s causing an issue with correct crediting of authors in OG results. How do we disable the review schema injection completely?
So for example if you want to remove the article and review meta this function should be deleted/commented – http://prntscr.com/ocxpcn -> http://prntscr.com/ocxnaw
-> http://prntscr.com/ocxphq
Then remove all of these – http://prntscr.com/ocxpyv – http://prntscr.com/ocxq8q
Then check in the page source to see if anything remains. Note that Yoast also loads schema, it could be removed like so – https://forum.tagdiv.com/topic/a-value-for-the-logo-field-is-required/
Thanks Anamaria
We got that far – but I think following your link to Yoast that the issue may be their side and that they don’t add schema to reviews in the same way. Thanks for helping us find that.
