Hi!
I have 3 problems:
1. There are no icons in the main sections (they used to be). How do I get icons back? Ideally, return the icons and size of the arrows as in the theme template.
2. The More section is located above the rest of the elements. How to make correct alignment?
3. The background (mesh) has disappeared, how to fix it? Perhaps this is only on large monitors, on a laptop there is a grid.
Screenshot:
https://pastenow.ru/77c1ed6b2f72cd0279ae61a28cd3e18a
SiteLink:
https://www.apartments.news/
Help me please.
1. The icons from menu in magazine pro were set using custom html and css for example -> https://i.imgur.com/C6U8BQ4.png another way to set icons is to use our guide from here -> https://forum.tagdiv.com/how-to-add-icons-in-menu/
2. The miss align is because the the code for these elements is not find and is displaying as in your website, removing the html code from menu will be display like this -> https://i.imgur.com/UU0sE4O.jpg
3. That background is displaying only for devices with a resolution like 1164px.
