In some modules on my website thumb size is different than it should be. How to fix?
https://zuov.gov.rs/obrazovno-vaspitni-rad-na-srpskom-jeziku-u-inostranstvu/
On home page, in module 1 – thumbs size is 100×50, bat it should be 100×70
Please make sure that you activate the option you need for the thumbnails size from Newspaper -> Theme panel -> Block settings -> Thumbs on Modules/Blocks.
After activating the thumbnail sizes you need to regenerate your thumbnails using a plugin. Check our guide from here: https://forum.tagdiv.com/using-the-theme-with-existing-content/
Hope that helps you!
Then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
