thumbnail and images not on right size
my images and thumbnails are not on right size automatically.
i already regenerate thumbnails a few times, but nothing has change..
it was right once, but i dont know what happened to resize like that..
http://www.inspiration.farm
att
Felipe Garchet
I have noticed that you are using Jetpack Photon, I think this could be the reason of this issue. Please disable all plugins including CDN and then regenerate thumbnails.
Hope this helps!
hey mate..
i did what you reckon but didnt work..
i deactivate jetpack and regenerate thumbs..
nothing change..
any other recommendation? ??
tks
Stop using jetpack ;-0
We use couple of plugins to automatically resize images, and also set featured image from image in post; and modify functions.php file to set default compression in WP at “60” (see my post on this many places in forum).
1) add to bottom of your functions.php file before doing regen thumbs
add_filter( 'jpeg_quality', create_function( '', 'return 60;' ) );
2) plugin to upscale images to fit theme sizes
Thumbnail Upscale
3) plugin to set featured post automatically
Auto Post Thumbnail PRO
tks mate.. it works
Always happy to help 🙂
Thanks Christopher for your help!
