Hi.
Thumbnail cropping does not seem to work.
https://prnt.sc/h2qwa6
Thumbs on Modules/Blocks,Has been fully enabled。
https://prnt.sc/h2qx57
The regeneration process will recreate all the necessary thumbnails needed for the theme modules. If you have regenerated the thumbnails and there is still a problem, please take note that the GD library is required to be installed on the server
– https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
You could check with the hosting provider if it is installed. Then there should be no problem with the thumbnails.
If possible please provide a link to your website so we can inspect it, if the issue is still present.
