Thumbnail Images not showing when using mobile theme plugin
Please help and check it here https://archishfertility.com/
Hello !
This is most likely because you will need to activate your thumbnail settings from Theme Panel – Blocks Settings – Thumbs on Modules / Blocks. The required ones as you can see in our guide too: https://www.screencast.com/t/7qip4qsf2tm are “265×198” and the “741×486”.
Let me know the results !
