Thumbnails not showing in footer and editor's picks and popular columns
I would like you to give me a solution to the problems I am facing WITH my site https://trikalatroll.gr/
1. Thumbnails not showing in footer and editor’s picks and popular columns
2. The popular category is not updated and some original articles are displayed while I would like the most recent popular ones to be displayed. what setting i need to do
3. The articles page In the sidebar I would like to put a column of Recently popular how can I do that
THANK YOU
Hello @giorgoskey!
1. It seems that you solved the issue: https://prnt.sc/jDdOfge_qxau
2. You can change the sort order of a flex block to Popular: https://prnt.sc/zHx1YRHjYG35https://forum.tagdiv.com/flex-block-settings-guide/
3. I explained how at point 2. You can have a row and split it into two columns. The second one can be your sidebar, where you can add any elements. In order to do that, you need to have a single cloud template.
We recommend using cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer, which contains a lot of functions and features, Please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
More documentation about the cloud templates is here:
– https://forum.tagdiv.com/cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/cloud-library-category-templates/
I come back to a problem that I still haven’t found a solution to,
In the footer of my site https://trikalatroll.gr/ there are two columns. Editor’s picks and popular articles.
While the editor options are updated, popular articles keep old posts rather than recent ones. How can I fix the setting so that I see recent popular posts.
Thank you very much
Hello @giorgoskey!
Please check the settings of that block and make sure the filter is set to “all categories” and the sort order is “latest” without any offset there.
Unfortunately I couldn’t do anything. I would like to ask how I can find this block. Maybe I don’t have access to the sweatshirt block. It also tells me that I cannot make changes to this footer with the tagdiv composer. The site is https://trikalatroll.gr/
Thank you very much
Hello @giorgoskey!
If it is not editable with the TagDiv Composer, then you should check in Appearance -> Widgets.
I have the same problem and wish to update “Popular Posts.” It’s impossible because TagDiv won’t edit/change anything that’s not a cloud template. I already screwed up playing around with cloud templates (some of which are really awful).
