Thumbnails problem
Hello
So far I love the newspaper theme, it’s really good.
But I have a problem with the thumbnails for the latest posts on the homepage.
The photos are not full size on the thumbnail, below you can see silver background.
How to fix that ? I tried to change sizes,but nothing helped me.
Thnx…
Please try to use images at least the size of the container you want them to show up in. The theme will crop images but it will not enlarge them.
If your images are large enough though, you can try this method: https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
Hello
That solution with the plugin worked great for me.
Everything is ok now.
Thank you
I got the same problem. The images are all 1024×768 pixel, so more large than their container but they still have that space on the right even after “regenerate thumbnail.”
Look at the screenprint.
https://www.dropbox.com/s/nxrk4sqnwrz5lqt/Screenshot%202017-07-21%2009.40.00.png?dl=0
How could I fix it?
Hello deporvillage,
Provide your website URL so I can take a closer look at it.
401 Authorization Required
where I can send you the credentials?
D.
Hello deporvillage,
You can send us an email at contact@tagdiv.com with your credentials so we can take a closer look at it. Also, provide there the link to this topic so we can quickly identify you.
I’ve sent you an email with the credentials.
D.
