Ticker problem
My ticker height has suddenly expanded.
How do I fix this problem?
https://blockchaintrailblazers.com
I believe your new update has created a conflict with the Cryptocurrency Widgets Pack from Blockera.
After I added the updated, the site and ticker worked fine until I made an update today. This expanded the height of the ticker. I tried disabling the plugin but the ticker height increased even more. I deleted the ticker plugin and the ticker expanded to become my entire home page.
I have a screenshot I can send if it’ll help.
I’ve restored a backup of the updated theme before I tried to make any edits to the homepage. So now I’m not sure if I made a change that created the problem, or there’s a problem with the code.
Once the problem appeared, I was no longer able to open the widget setting page.
Now with the backup of 9.01 restored I am able to access the widget plugin settings.
I can’t say about other ticker plugins, we only tested with the plugin that the cryptocurrency demo is using. This one
– https://wordpress.org/plugins/cryptocurrency-price-ticker-widget/
But the plugin has issues in the latest version and it will cause problems until fixed
– https://wordpress.org/support/topic/last-update-broke-my-ticker/
– https://wordpress.org/support/topic/can-you-please-send-1-8-2/
From what I can see the ticker looks alright in your website
– https://www.screencast.com/t/nmVXCaKUHVQf
What exactly is wrong with it?
