Hi Emil,
Thanks for the Newspaper Version 6. Its just awesome and very easy to use. The only problem we are having is TinyMCE Advanced is not working. Whenever I am tying anything in the VISUAL editor, nothing shows up except the tool bar and when I hit save nothing is being saved, just a white page. I am confused and in our previous version it used to work brilliantly.
Please help me with this issue is you can.
Team Omni
I’ve tested tinymce advanced on my side, i’ve created a new post, added some text, images and a featured image and the post was saved without any problem. Try to disable the rest of the plugins except for Visual Composer and Tinymce advanced and see if the issue is still there.
Hi Emil,
Thanks for your suggestions. However we deactivated all the plugins except tinymce advanced and Visual Composer and tried but still we don’t see any texts in the new posts while it is created and saved. The issue still remains.
Team Omni
Hi Emil,
We have even checked with disabling all the plugins and clearing browser cache but the Tinymce Advanced is not working. We also tried out WP Edit but thats also not working. Whenever a post is saved nothing comes up and also the preview is not showing up whatever is written inside the editor window. So our guess is that there is some problem with WP Visual Composer. Can you please check with our wordpress admin access?
Team Omni
