TINYMCE ADVANCED PROBLEM
I have tinyMCE installed on my website, i need some more options for styling the posts because the theme has not many. I already had the plugin activated before to install the theme and now i found out that if the plugin is activated i cant see in the format dropdown menu the dropcaps, quote etc from the theme.
Can you help me or point me to a plugin with similar feature that gives no problems?
http://nimb.ws/3SRwHA
http://nimb.ws/y0gLNm
thank you in advance
Hello STEFEN1,
Unfortunately, this type of plugins is not tested with our theme and we have no idea about the theme behavior with this plugin and also, we cannot say for sure if it will work or not with the theme, sorry! We cannot make any recommendation in this regard because we do not have made any tests with other plugins in this case, sorry!
