Title in post view is too low
I am using the post style 8 to show my news, but as you can see in the posts, the title and post information is showing to low, part of the title is hidden below the taskbar, I have to scroll to see it complete.
In the demo the title and information shows well, how can I fix it?
This is my site: http://www.guatefutbol.com/nw/
Hello guatefutbol,
I have inspected your website and I did not say any problems with your post title, sorry! It seems to work as expected. Provide more details and also, some useful screenshots so I can identify the problem. Clear all your caches and check the results.
Please see the screenshots, the title in my site is partially hidden by the taksbar:
View post on imgur.com
And in the demo site, everything shows well:
This is ocurring with all posts, my monitor resolution is 1366×768.
Please help.
Hello guatefutbol,
Provide your website so I can take a closer look at it and also, so I will be able to provide a more accurate response. Also, if you are using some untested plugins, you should remove all of them, leave just only the required plugins to active, clear all the caches and check the results.
I followed your advice, but the problem persists.
You can see my site here: http://www.guatefutbol.com/nw/
I have inspected your website, and everything is working as it should. There are no errors present on your website.
I believe that is the way the website is displayed on the resolution you mention. Basically there is no space to display the whole title on that specific height. On other devices it will look differently. You could change the post template if you would like the posts to display better on your monitor resolution.
That small difference between the demo and your website is coming from the header. The demo uses Header style 6 which is more compact
– https://www.screencast.com/t/zkbj0WWs
Opposed to Header style 1 that you are using at the moment.
