Title Spacing Problem
I’m trying to add a section title to my homepage to go over a non-Block Visual Composer element. Right now I just have an empty “Text with Title” element with my carousel element under that. However, that’s causing uneven spacing (as circled in the screenshot)
Title Gap
Is there a better way to accomplish this or remove the spacing between the elements? Also, how do I add a URL to the Title in the “Text with Title” element? It’s an option on the Block-related elements, but not in the “Text with Title” element.
I guess that you have this space issue because of text with title margin and padding bottom. Try to add your title using Raw Html block like this(also you can add your link) – http://screencast.com/t/eUhlIK0TL – http://screencast.com/t/dqCtqkZ6R2gd
<h4 class="block-title"><a href="http://your link">
MOST POPULAR
</a></h4>
Unfortunately the Text with Title block doesn’t have an option to add a link like the theme’s blocks have.
Thank you for the help! That worked perfectly!
-Luke
