Hi guys,
I noticed that when I create a post with paginated articles the page title is not updated when I click on the next/previous post.
For example, the URL does change to something like dogs-ready-for-summer/2/…dogs-ready-for-summer/n/. However, the Page title remains as “11 Dogs Ready for Summer” instead of “11 Dogs Ready for Summer – Page n” or something like that.
Is there any way you guys can help me with this? Thanks in advance.
This is a default behavior of WordPress. It is not controlled by the theme. It only adds a number to the title like so: http://screencast.com/t/cTqjRRWMpmpj You will see it displays like this on a WP default theme as well.
Hi Bodgan,
Thank you for the response.
I was referring to the title meta tag in the header section of my site. As I pointed out before, the title in the URL bar is being updated fine.
I am using a plugin for pagination. Not sure if your theme is responsible for this change or if the plugin is.
Here is a sample post http://fourleggedguru.com/dogs-ready-for-summer/
If you click on the next button, that’s when the issue I’m having comes into play. I’m getting duplicate content warnings because of this and would like to correct this ASAP.
Thanks!!
Hi Chris,
Thank you for your response.
I have that setting turned on in Yoast SEO and it works as it should for normal pagination pages.
Please see the examples below(This site makes use of the setting in Yoast you referred to)
Page with custom slider and no title change: http://fourleggedguru.com/dogs-ready-for-summer/
Page with normal pagination and title change as provided by Yoast SEO: http://fourleggedguru.com/category/breeds/
Could it be some other settings colliding or something of that nature? Thanks for any feedback.
