I don’t see a save button in the WP editor in the cloud template environment. I take the following steps:
1. Add element -> add the text with title element
2. Select the element -> click on “Edit content”
3. A windows appears (WP Editor).
I can edit everything, but I don’t see a way to save the content. If I click on the cross icon the changes I maded are gone.
Any tips? (Both tested in the Google Chrome and Opera).
Best regards
Ensure that you are using the latest version of the theme installed via FTP way, clear all the caches, purge CDN files and check the results. Also, please check here -> https://www.screencast.com/t/9mTJyKpZNp
Thank you! I did this and it still is doing the same thing. One note to make is that it does not seem to load fully as well. The text editor does not appear.
Hi all,
Please check the system status parameters to be increased according to our documentation from here -> https://forum.tagdiv.com/system-status-parameters-guide/ Probably, your PHP memory has exhausted and that’s why this happens.
