titles and article meta information do not appear in flex blocks
When I use flex blocks of the shortcodes, I don’t get the title or the meta information on the home page. This is my second webpage with newspaper and I have not had any problem with this in the first one
  • This topic was modified 7 years by sergi.
Please provide some more details about the flex block you are using -> http://prntscr.com/oxkg00 -> http://prntscr.com/oxkg8f -> https://forum.tagdiv.com/flex-block-settings-guide/
in this way I will be able to provide you some more help!
Thanks Calin, I solved the problem by changing the demo model. The mistake was with demo food recipes. Now I use Baby blog and everything is perfect
