In the categories feed, I use “Flex block 1” and “Posts loop” below.
May I use “Flex block 1” for some categories, and, for example, “Flex block 2” for others?
Or may I use “Flex block 1” with visible images for some categories and hide images (Flex block 1 – Layout – article images – hide image) for others?
Same for “Posts loop”:
May I use “Posts loop” with Modules per row = 1, with visible image, and for some categories configure Modules per row = 2 and Hide image on?
In general, is it possible to make the newspaper theme more flexible?
Could you help me?
The answer is yes and no.
You can use different flex blocks and loops per category if you create different category templates and you assign them to those categories, but not to the same category template.
For example you can create a category template that will be used on most of the categories, this will be set as global https://prnt.sc/7RxaX0PI4tqQ then you create one extra template (or as many as you want) that will be assigned individually, for example – https://prnt.sc/YI7ui-Q-beyG
