To work a web with 1400px wide
Hello
I need to work a web with 1400px wide. Is it possible to extend the width to 1400px and 4 columns?
Thank you
Hello fermin,
You should use the Cloud Library, import from there such a template for Category, Single Post because there you will see the option for width, like this -> https://www.screencast.com/t/1ykAwMY3j
Hi.
I will do a test.
regards
Hi.
The header and footer can also be extended to 1400px.
Thank you
regards
Fermin
