Tooltip balloons disable on Newspaper and element stretch help
Hello dear
At https://argolika.gr/
We have Newspaper and i would like to disable Tooltip balloons
(ex: popup white messages with the article titles when you let te mouse on)
also i have two black elements that i want to be stretched horizontally
(the black backround color from edge to edge)but i can’t succeed it.
Can you please help me
regards
If you referring to this option -> https://i.imgur.com/nAjOTkq.png you can disable it from here -> https://i.imgur.com/SqNHdwZ.png
If I understood correctly, you can stretch the row like this -> https://i.imgur.com/FwaB8MN.jpg
Hello again i mean about this
https://imgur.com/a/JHz0pH0
And i think i have tried this option about stretch many times
but didnt change but i will try again and i call you back
So you are referring to the title of the post? A workaround there to have full text please check the settings for meta info -> https://i.imgur.com/TFYjQd6.png
Hello again
what i mean about this
is I dont want the white box with the title to appear
Please check this topic https://forum.tagdiv.com/topic/disable-image-titles-on-hover/ and use that JavaScript code.
