Top article sharing problem after update to 8.6
Hello, i have more problem with my article sharing after update Newspaper to version 8.6
My article sharing now are on the left of my article, i need in a center, and my like twitter is disappeared.
Why?
Before with version 8.5 everything was fine.
My website: https://www.pcusb.it
The Twitter button was meant to be removed some time ago, it served no actual purpose since Twitter decided to stop displaying a tweet count on the button.
I could try and give you a solution for the socials, please specify exactly how you would like them to be aligned.
In center of the page, thanks.
The Like button was moved on top of the sharing, because in case there are more socials present it would interfere with them
– https://www.screencast.com/t/Fo2eapQlR
That is why placing it on the left or right of the socials will not work anymore, it can cause problems.
Thans
Like button is ok for me, but button social sharing need on the center…
They could be centered with a code like this one
– https://www.screencast.com/t/wxA11Ryp
.td-post-sharing {
text-align: center;
Thanks…
