Hi Support,
i added an ad sticky ad that suppose to appear by the left margin of my website, but part of it is covered by the top frame, you have scrol down in other see the full ad.
Attached is the image of how it looks
1. How do i bring the ad to appear in front, instead of showing under
You can see here when i scroll down you see the full ad
Our theme has no options for such an ad spot. if you add something custom, you will have to test it out for any problems you might find along the way. such as the one you mention. You can try to add a higher z-index to your sticky ad: http://www.w3schools.com/cssref/pr_pos_z-index.asp
I added it on the head using wp insert code plugin
Hi support,
i implemented it on http://www.nigerianpilot.com and it still showing the overlap
http://nigerianpilot.com/budget-padding-jibrins-suspension-unconstitutional-femi-gbajabiamila/
this is the code
<script data-cfasync=”false” type=”text/javascript” src=”//www.eboundservices.com/ads/sticky_responsive.js”></script></script>
i added it on the head,
Well if you change the the theme width it is clear that the ad will overlap Where can it display if the screen width is occupied with content. Do not change the theme width and there will be no more overlap on that page. Please remove any at all width altering code as our theme was not designed to display full width.
Hello willysawa,
I have inspected your website and I saw that you homepage layout is damaged. Please try to make a new homepage from scratch and check again the results. Also, if you are using some untested plugins, please try to disable all of them, leave just Visual Composer to active, clear all your caches, purge CDN files if you are using the CDN system and install only the plugins that come bundled with our theme and rule out the conflicting plugins.
