Hi there 🙂
I searched the forum for a solution but couldn’t find it…
Check my website >>> http://www.electro-swing.com
On safari, I have 2 lines in the top menu when I add the login widget.
I tried this: http://screencast.com/t/YxZYV9ZV
But it doesn’t work for me.
Thank you very much for your help & time
julien
Hi Lucian!
thank you for your quick answer and solution.
I tried it and on chrome, the problem is solved when user is not logged. The same problem comes back when user logs in. I tried to change to this value >>> margin-right: 8px. It solves the problem.
Then I tried to log in with long usernames: the problem comes back again.
Any idea?
thanks
Please change the span classes like here: http://screencast.com/t/YxZYV9ZV This will enlarge the space there and the logo will fit http://screencast.com/t/tbyUjgf9
