Top Main Menu not expanding to edge
Hi, I’m using Gourmet Pro. I want the top menu row to expand all the way to the edge of the screen. I can’t figure out where to do this after searching a lot in TD composer. My top menu has background color so it looks very weird now because there’s a lot of blank white space on either side of the menu. Thanks.
You can edit the Gourmet Pro using tagDiv Composer, you just need to select the row that is holding the top menu you have an stretch it -> https://i.imgur.com/EUZygkL.jpg or for sticky menu click on header manager -> https://i.imgur.com/7UUU7fT.png
If there is still a problem, please provide me a link or some screenshots where I can inspect the element you want to change.
Thank you. That worked. So another similar problem:
In my blog posts, I want ONLY ONE COLUMN that expands the entire screen where I have my article text.
I don’t want the narrow right column with all the “widgets”.
How to do this? I tried deleting all the elements in the right column and expanding the row (as you suggested to my previous problem) but this didn’t work.
Or is there a cloud template that exists with ONLY ONE COLUMN for blog post that you can suggest?
Now depends on how was the blog made. If the blog page was made using tagdiv Composer, then you can adjust it using tagDiv Composer. If you have selected in WordPress the first page as a blog -> https://i.imgur.com/3senT19.png then you need to use the options from theme panel -> https://i.imgur.com/o6BXgQj.png
If there is still a problem, please provide me a link to your blog, in this way I will know how this was made and I will be able to provide the right steps to make these changes.
