Top menu does not appear on mobiles
Hello Sir,
Top menu does not appear on mobiles , how to fix it.
you can check for it in the newspaper tech demo site too on mobile..it doesnt appear on mobile devices, as such such a nice menu bar gets wasted 🙁
Awaiting reply
Best regards
The top menu does not appear on the mobile version by default. This was a design choice. It can however be activated with custom css:
@media (max-width: 767px){
.td-header-top-menu-full {
display:block!important;
.td-header-sp-top-menu{
.td-header-sp-top-widget{
display:none!important;
I hope this helps.
