Top Menu does not display on iPhone (small screen)
My question is: how do I get the top menu (which contains my date, login,subscribe, about and social icons) to display on small screens (e.g. iPhone 6). I can see the top menu on a computer and tablet (i.e. iPad) but it’s not displaying on my iPhone.
Is there a setting I need to adjust?
p.s. After struggling with other Newspaper themes in the past I discovered Newspaper6 and was immediately impressed! Great theme, even greater doc support. Thanks.
Thank you for your kind words and appreciation.
The top menu was hidden on the mobile devices with css as a design choice by the developers. It can be reactivated though but we will require a link to your website so I can create the code directly.
Hi Bogdan,
My website link is
do youWebsite Link
don’t know if you require the wp admin password or not, let me know.
You can use this code to add the top bar to the mobile version:
@media (max-width: 767px){
.td-header-top-menu-full {
display: block!important;
.td-header-sp-top-menu {
display:block!important;
I have the same solution to do but I try to use this css but on iOS don’t show the top bar menu this is my web site https://www.thunhoon.com/, Please provide the best solution
thank you
I have checked your site and on both android and ios the top bar displays at the top of the page. The display: none and display:block css parameters are not OS dependent. They will work on any browser and any OS.
