On the home page: https://smallcaps.com.au
The top two sections of the main Big 4 grid do not allow the text to be full width.
As a result the title gets squashed up and takes up much of the image.
I have placed text to highlight here what I wish to achieve:
https://smallcaps.com.au/wp-content/uploads/2017/04/Top-two-Big-Grid-4-posts-not-allowing-text-to-be-full-width.jpg
If you can please let me know how to achieve this.
Hello WakeUpCallProject,
I have inspected your website and I saw that you are using the Big Grid 4 for your top of the homepage. If you want to display in full width the text of your meta info container, you should use a bit of CSS and make this container to be 100%.
The code is ->
.td-grid-style-1 .td-big-thumb .td-big-grid-meta {
width: 100%;
The result is here -> https://www.screencast.com/t/SLLQy41Kd
Thanks that works great. 🙂
Also I noticed the Big Grid 4 darkens the feature image. Is there a way to make it less darker (as a %) or have it the original image colour?
If you want to make this container to be darker, you should apply a background-color with opacity (RGBa) on this container. For more information about how this can be done, please consult here -> https://www.w3schools.com/cssref/tryit.asp?filename=trycss_color_rgba
