Hello
Images are looking different heights on laptop and desktop. I have asked about this three times already an no one is given me a fix and just saying to me (it should be responsive) or I can change the heights.
1. They are not being responsive
2. Changing the height does not work because it makes both worse as it changes both.
Once more my issue………………..
Currently, The main images (middle top_ are fitting okay on desktop screen) But on latop they are showing to long causing things not to be square.
Now. If I am on my laptop and make the these images shorter in height so they fit in the laptop screen, they will be come to short on the desktop screen PC. Or VISA VERA
See here!
On laptop screen – TOO HIGH https://prnt.sc/f9Arau-wEk2M
But on desktop PC screen fit okay https://prnt.sc/-zKIe2uHzpOi (CORRECT FITTING)
If I change one. It make the other not fit.
How to I make both FIT correct at the same time. It is not responsive are your past suggestions suggestions do not work, It will cause the other screen to come wrong
This is obvious issue with this this theme
Adjusting via different view ports does not help https://prnt.sc/yhFPPYILlVc0
Impossible to get both of these correct Uniform size of both desktop PC and laptop computer
As you will see. On the laptop computer it needs to be shorter. But If I make this shorter to fit the laptop screen nice. It will make the DESKTOP TO SHORT (when it is fitting correctly already)
Cannot win here
