Nothing happens when I Load theme available translation (I load Thai languages). Or there more steps to do in order to load the translation properly?
Unfortunately, more and more users report having this problem with the Translations but we have not identified why this happens yet. We cannot recreate this issue to our side. Therefore, please provide as many details about your configuration because the reasons that can cause this error are quite different. Also, please try to disable anything else which you think that influence the good functioning of the theme -> Ad Blocker, try the theme on more than one browsers.
If you are using the https URL, please try to follow the next steps for your Translations. Try to load your desired translation from panel and then you can see in left corner of your browser, an icon with a shield and then try to Load unsafe scripts, like this -> http://screencast.com/t/aLm2aAFv5
Also, if your problem is still there, please try to translate manually your strings from the theme panel, like this -> http://screencast.com/t/s6bfE5NI6t
Also, you can send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can take a closer look to your setup page and also, so I will be able to provide a more accurate response. Please provide there the link to this topic so we can quickly identify you.
I have the same problem.
And it displays this time-out error.
Hello ihering,
Please keep in mind that the Translation feature is fully compatible and tested with the theme and seems to work as properly until now. Unfortunately, more and more users report having this problem with Translation but when we try to see where the problem is on their site, it works. We cannot recreate this issue to our side. Therefore, please provide as many details about your configuration because the reasons that can cause this error are quite different. Also, please try to disable anything else which you think that influence the good functioning of the theme -> Ad Blocker, try the theme on more than one browsers.
