Open up the console and that was there:
was loaded over HTTPS, but requested an insecure script ‘http://api.tagdiv.com/user_translations/get_translation?callback=jsonpCallback&language_code=pt&_=1464400386052’. This request has been blocked; the content must be served over HTTPS.send @ load-scripts.php?c=0&load[]=jquery-core,jquery-migrate,jquery-ui-core,jquery-ui-widget,jquery-ui-mo…:4
can you guys enable https?
I recommend letsencrypt.
If you’re using docker, with a nginx-proxy there’s even a docker for that:
https://github.com/JrCs/docker-letsencrypt-nginx-proxy-companion
Hello panthro,
If you are using the https URL, please try to follow the next steps for your Translations. Try to load your desired translation from panel and then you can see in left corner of your browser, an icon with a shield and then try to Load unsafe scripts, like this -> http://screencast.com/t/aLm2aAFv5
