Translation problem
Hello
I load a polish translation in admin panel successfully.
The problem is there whene i click in admin panel on the translation section a button save settings the proccesing is working and i wait 15 minutes and processing is still procesing and can no done. I wait longer about 30 minutes and the process is running and still not done ;(( Can you help me wha i must done to succesfully done my process??
I must reinstall wordpress or clear something??
Please help me or send me a screenshots:)
best regards
Wiesława Kłos
Hello Wiesława Kłos,
First of all, please ensure that you are using the latest theme version, right installed via FTP way and then check your system status parameters to be according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/ Most likely, all of these parameters are not correctly increased and that’s why you have some errors regarding on saving.
