Translation problems
“If you’re not happy with the results, please do another search”
“We’re sorry, but the page you are looking for doesn’t exist.”
these lines can not translate. when i translate it via theme panel and save it, these lines will be blank after refresh.
We know about this issue, for us works great but is some unknown cases don’t work. We will fix it in the next update Monday, if not work for you a simple solution is to change it directly from file.
