Hi! After following the steps to change the language translation (from Newsmag tutorials page), it won’t work. Just don’t load the new assigned language nor saves the changes in the fields of “translation” tab. How to proceed?
Please try to increase your system status parameters as this guide shows: https://forum.tagdiv.com/system-status-parameters-guide/
If you use the wordfence plugin, please set the firewall to learning mode.
If this is not the case, then please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
Let us know how it goes.
