For some reason my site has the whole main content container as transparent and I don’t want it that transparent. Other posts look weird as well because the post box is white while the outside container is transparent.
How do I make these two things consistent? I tried looking through Theme Colors in the Theme Panel but there was no luck.
The background transparency comes from the following file – http://screencast.com/t/6H42FHMsU Do you use a plugin which alters/combines the css? Try to disable all plugins except of Visual Composer and see if the issue is still there. If you use CDN disable it and check again.
