Travel Guide Demo – Front Page Banner
We are using the Newspaper theme/Travel Guide demo, which we purchased last month.
We have replaced the banner.jpg at the top of the front page with an image of our own (as well as changed some categories displayed on the front page, etc).
The image appears stretched/blurry. We have tried dimensions of 1920 × 815 as well as 1235 × 524. In the attachment display settings, the size is set to Full Size.
Please advise what changes we can make so that the image is not stretched or blurry.
Thanks in advance for any help!
Please contact us via email at contact@tagdiv.com and provide wp-admin and a link to your site so we can login and investigate.
I have the same problem, I insert images with different size. But image is blurred
  • This reply was modified 8 years by Evgeny13v.
@Evgeny13v
There should not be any issues. The live demo uses an image of 1920x815px as background. Test with similar images, the result should be proper. Just make sure that when selecting the background image, you select full size
– https://www.screencast.com/t/0F38XvU3
– https://www.screencast.com/t/j3b1DtNk73w
What about the footer background image? The forest footer background that is used on the Travel theme style measures 1235 x 378 and it’s blurry when I add it to the footer area.
Then add a bigger image in size. You do not need to use the demo images, upload and set your own images as background. Experiment with different images until you get the desired results.
