Tried using a template with amalinks pro it stretched its images
I need help with a template that i have used..
How to fix the images that is being used by amalinkspro plugin.
Or is there a settings to check size of the images in the imported template.. Its a single post template.
I cant seems to fix it.
I do not quite understand to which single post template you are referring, please provide some more details and some screenshots.
where can i send this privately?
i dont want to show the site here
hello?
is any support available?
hello?
please. I need to have a fix on this
Please replay only in your topic or in topics that have a similar problem with your problem, also notice that we take in order of time ( time when was post the question ) to answer the question, and if you post/replay again in your topic the time will change and will be move to recent question, therefore the answer will be delay.
You can send us an email at contact@tagdiv.com and include a link to this topic in the email, in this way wold be more easy to identity the problem.
