Trouble With Changing Fonts
I have been trying to change the default to another combination of Google Fonts but no matter what font I try nothing seems to change? I have checked that they have the standard weight of 400 and as far as I can tell they should work?
Is there a doc/help file that you can point me too so that I can make this work.
Sara
There are many theme settings regarding fonts, in the theme panel
– https://forum.tagdiv.com/font-customization/
There you can change the fonts and font properties for most elements. Also now the fonts on blocks and other elements on pages can be customized directly while building the page with the tagDiv composer
– https://www.screencast.com/t/Ee55XAXuo0
Each block for example can have it’s own font settings. This offers an alternative to the general theme panel font settings.
If you could provide some more details about the problem you are having, for what element the problems happen and in what circumstances, it would be helpful. A link to your website where the problem/element is question is happening would be useful as well.
