I’ve been trying to use “td_module_mx1” in “Article Display View” for categories in the theme panel but I just haven’t had any luck getting it to work. I read https://forum.tagdiv.com/api-modules-introduction/ and tried to modify “td_module_mx1” to show up in “Article Display View” through “td_config.php” but it doesn’t work when I select it.
Any help is appreciated, thanks!
The MX modules were never meant to be used outside of their scope. We have no easy solution to provide in this regard as the api is not covered by the theme support sorry. You will have to get some hired help on this as we have no customization department.
