When we run the twitter card validator for any of our posts at our site warnews247.gr we always get the following error: “WARN: No metatags found”
It also seems to work just fine for static pages like our homepage and category pages.
When we Curl a post page like “https://warnews247.gr/oi-rosoi-meta-ton-tourismo-chtypoun-kai-tis-tourkikes-metafores-den-afinoun-ta-fortiga-tous-na-epistrepsoun-stin-tourkia/” using the Twitterbot user agent string we get an error page with the wp-die-message and the following error on our webserver log:
AH01071: Got error 'PHP message: PHP Warning: require(/var/www/vhosts/warnews247.gr/httpdocs/wp-content/plugins/td-standard-pack/Newspaper): failed to open stream: No such device in /var/www/vhosts/warnews247.gr/httpdocs/wp-includes/comment-template.php on line 1554PHP message: PHP Fatal error: require(): Failed opening required '/var/www/vhosts/warnews247.gr/httpdocs/wp-content/plugins/td-standard-pack/Newspaper/' (include_path='.:/opt/plesk/php/7.4/share/pear') in /var/www/vhosts/warnews247.gr/httpdocs/wp-includes/comment-template.php on line 1554'
It seems to be working ok if we use any other type of user agent.
Any help would be appreciated
Please check this topic because it could help you: https://forum.tagdiv.com/topic/twitter-card-do-not-load-it-only-resolves-after-3-hrs/
