Hi.
I have coauthored posts. Can I have two author cards in the same post?
Unfortunately the theme will take into account only one author of the post. Using a plugin and modifications in the theme there was a solution to display more authors in the post template, like this – https://forum.tagdiv.com/topic/co-authors-plugin-code/
But to display author boxes for each author there is no similar topic I could provide, with an example. I don’t think this was attempted before.
From what I know an easier integration with the co-authors plugin will be taken into consideration by our developer team, when that happens we will provide documentation for it. For the time being the theme will use and display only one author for each post. Sorry for the inconvenience.
The link to the code throws a 404:
Here is my own version: https://github.com/renduples/tagDiv-Newspaper-CoAuthors-Plus
@MG Dev The links seems to work now – https://pastebin.com/chADk3Xw but thank you for posting your version. It may be helpful for other users.
