Two Columns Blocks Rendering Single Block
The homepage at http://lowcosthousing.online/ has a couple of two column blocks (block 16) at the bottom, however, they are both rendering information in single column. Kindly check and help to resolve.
Well this is the way a block 16 displays content on a single column: https://www.screencast.com/t/G3TK8wqwn
The site is split in 3 sections. A block 16 needs 2 columns to display like so: https://www.screencast.com/t/TJX5M1cCJ
You cannot have 2×2 column layouts on the page as that would mean the theme needs 4 columns but only 3 are available.
Ok so how do you suggest that I have 2×2 layout with each 50% having 4 columns to display articles? Can i design such a block myself?
You can use any block available for your page – https://demo.tagdiv.com/newspaper/block-1/ with this layout
https://forum.tagdiv.com/how-to-use-visual-composer/
This is how it is recommended to create your page structure, please try and use a combination of blocks and layout that you think it is suited for your website, using the theme options.
If you would like to create your own block, you can do so using this guide
https://forum.tagdiv.com/practical-example-how-to-add-a-new-block-and-module/
Or you could modify an existing block through the child theme
https://forum.tagdiv.com/the-child-theme-support-tutorial/
I didn’t understand this. Kindly let me know if there is some ready code snippets that I can implement to get a 4 column layout with 50:50 column widths.
Also, my employees are not being able to register on my website with lowcosthousing.online as domain name. How can this be fixed?
What I was trying to explain is that you can only have a maximum of three columns
https://www.screencast.com/t/21hWQIH7lA
And you should find a way to use this layout when building your pages. This is recommended, and also guarantees that the page building elements from Visual composer will display properly.
Please provide more details about the problems you are experiencing with the registration. If users are not able to register, make sure this option is enabled – https://www.screencast.com/t/KFGKNDZRSrc
There you can also choose a default role for the new users.
Users are not being able to register using email addresses with domain .online. E.g. saurabh@lowcosthousing.online cannot register.
There is no theme setting that can affect the user registration with the domain you are using. I believe that if you want to have email options, there are providers that can offer this solution. Please check with your domain hosting with this kind of available options.
