I just added a custom icon for Mastodon in the social media section of my header and footer.
But when inserting the link to Mastodon like https://literatur.social/@literaturcafe it can’t be inserted. It is saved and trunkated as https://literatur.social/#
And how do I refer to that custom icon in the “Order social icons” field? I try “extra”, “custom” “Mastodon”, but non of them worked. The icon is always sorted at the end.
Hello @be2name!
Did you check in the tagdiv composer which settings you have there?
Can you please provide some screenshots with the settings you’ve applied in the tagdiv composer or theme panel?
