Hi guys, i’m facing two problems :
1 – The first one concerns how to minimize redirects from http to https. I’ve done everything with my host, my database, wordpress, plugins and cloudflare… but some redirects remains as you can see on this report :
https://www.screencast.com/t/GUwcH4DHU5q
It concerns image only, that I add in background with tagDiv composer… and I managed to remove 6 redirects, by removing and adding again the image. But as you can see here : https://www.screencast.com/t/Vw7XnufDh4nT ; there is still an image I’m fighting with. It is the background of the menu of the nature theme. How can I remove it (if possible), or how can I modify it to put it https (by modifying the code, I don’t want to add something in the htaccess if possible) ?
2 – My second question concerns the td-newsletter and recent GDPR things. Normally, we are supposed to add an opt-in option with the input form when the suscriber enters his email right ? But when i add the embed form (from mailer lite in my case), even if i add the opt in option when i’m creating the form on mailerlite’s website, nothing appears using the td-newsletter plugin. So as you can see on my website in the footer, i add the embed form with raw html, but it is not very convenient…
Could you help ?
1. Check in the theme panel background section here
– https://www.screencast.com/t/qbhoLnBM
Remove/replace/re-add the image found there, then check if the problem is solved.
2. You would probably be better to use a simple text element to embed the form, then all your fields will be displayed. The newsletter widget may not display all your fields, only the email. Our plugin is at the beginning, it will receive more updates in the future. Try placing the form in a text element and there should be no problem.
1- Wow thank you Simion I forgot to check here ! I removed it, it is still not appearing in gtmetrix, I guess it takes time.
2- When I said it was not convenient, I meant in term of customization (colors etc). I let like this, and I’m waiting for next updates.
Thank you again for the support, fast and effective !
