Two Problems
Hi, I have two questions :
– I want to put the play symbol on the outstanding images . My website is a tube .
– I want every class to have a different sidebar . I tried from the control panel but not the witches is.
I hope you can sorting doubts.
Thank you
1. If you use video posts you have to change the format to Video – http://screencast.com/t/dDzyOCUd
2. You mean to use a different sidebar for each category? you can doit from Theme Panel -> Categories – http://screencast.com/t/w1nBHhsOBhttp://screencast.com/t/WZHn9KdAdvpW
Hello, Thanks for your answer .
But when I try to change the sidebar , not let me. Follow saliedo the default sidebar
Want access ?
Sorry for my english:
But when I try to change the sidebar , not let me. Still leaving the default sidebar
Want access ?
Please check the max_input_vars directive from you php.ini file and make sure that it’s set above 2000, you can check this in system status section within theme’s panel: http://screencast.com/t/V8MumQISR Contact your host provider and let him know about this if you can’t access php.ini file. Let me know how it goes!
