Two Questions: Deleting More Stories Popup on Mobile & changing text box width
Hi, how can I delete the more stories popup on mobile. When I scroll down, it blocks a lot of text. I like it on desktop but not on mobile.
Also, how can I change the width of the box the text is in. Here is how it currently looks with your theme:
https://imgur.com/a/Od9R1WS
Here’s what i want it to look like:
https://imgur.com/a/oksHXlD
To disable the more stories popup from mobile you’ll need to use this custom css:
body .td-more-articles-box{
display: none;
Please set this code in theme panel > custom code> advance css> in phone section.
Unfortunately, the Newsmag theme do not have an option like the Newspaper theme to can change the post width, the only option it is using a custom css.
I think that you can try this custom css
.single .td-pb-span8{
width: 75%!important;
.single .td-pb-span4{
width: 25%!important;
You can adjust the width for the columns
