Two small problems
Good morning, we have a couple of minor issues to be submitted to the staff. The first concerns the comments, We have ordered the closure of the comments after 30 days. With the commenting system default comments in articles that exceed 30 days are not seen. If we use a third-party plugins (comment plus) instead are seen, but the plugin is heavy or comments and we would like to use the default or the new plugin WPDISCUZ but behaves as the system default
Second problem, the images in the post template style 4, 5 and 6 retain their original size. is not the same for the Newspaper theme.
How can we solve this problem?
Regarding the first problem you have please note that we have this on our todo list an we’re working on it and we will have it fix in next theme versions.
The images used for post template 4/5/6 is the td_1021x580 image thumbnail they are not loaded at their original size:
ex: http://screencast.com/t/0vOmUbxV
Make sure you use this guide an regenerate your thumbnails if this is not happening in your case: https://forum.tagdiv.com/how-to-fix-strange-thumbnails/
Let me know if this is not what you’ve refereed too and provide more details and your site’s URL also.
Thanks Lucian for replying. We regenerated the Thumnails (again) but the result does not change as you can see in this link
http://www.rightsreporter.org/ennesima-trovata-palestinese-violenza-sulle-donne-in-aumento-ma-e-colpa-di-israele/
For comments we waiting for new developments
our website http://www.rightsreporter.org
Please make sure that you also upload and use an image at least 1021px wide and 580px height as WordPress doesn’t enlarge images, you would need a plugin for that or custom css to stretch them: http://screencast.com/t/HKss39XQjYQ
Please let me know!
Ok, so the image has to have that dimension. We thought it was like the Newspaper theme that fit the image to the type of style even if the image was smaller
Thank you very much. You are very kind
